Weird Issues after update '.158'
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-07-2021 03:38 PM
Model Name: ROG 3
Firmware Version: Not Showing in settings
Rooted or not: No
Frequency of Occurrence: 24*7
My phone was working perfectly fine up until the update ending with '.158' was installed. There are 2 major issue I have noticed and they're both pretty weird.
1. The side mounted USB port allows for the headphone to be connected and works perfectly when a headphone is connected but as soon as I connect the charging cable to it, it starts charging for a mili second and immediately stops charging. It gives the idea as if the port or the charger is busted.
However, the charger works perfectly in the bottom port and charges the phone.
2. Snapchat and Instagram have stopped recording videos in-app. Whenever I try to record a video through any of them, the app just clicks a picture instead. Also video calls on both app results in the person I am calling not being able to see my face.
However the problem seems to be only in these 2 apps since video calls work in Whatsapp, Telegram, etc. I am using latest updated versions of both apps.
Hopefully it's just a bug and can be resolved via an update but I'd appreciate any thoughts given as to why is this happening.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-07-2021 07:54 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-07-2021 09:23 PM
Lord_MessiYou mean factory reset?Reset your phone and you will be fine
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-07-2021 11:13 PM
illixirYes it is. It should work after thathttps://zentalk.asus.com/en/discussion/comment/185239#Comment_185239
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-08-2021 08:59 AM
illixirYou have to do factory reset in order to see if port issues gets fixPlease tell us some basic information before asking for help:
- Model Name: ROG 3
- Firmware Version: Not Showing in settings
- Rooted or not: No
- Frequency of Occurrence: 24*7
- APP Name & APP Version (If your issue relates to the app):
And yes update sometimes messes up with permission issues and factory reset will fix those video recording issues and its not to be worried about
