02-16-2021 10:43 PM
02-17-2021 12:24 AM
02-17-2021 01:40 AM
02-24-2021 10:23 AM
02-24-2021 10:38 AM
Eagle GrooKrooYou are having almost same issue as this user so try to maintain same in issue in one thread so that everyone can have same answer at once and no confusion takes place check this one :down_arrow:Any updates on software end bro? Or do I need to visit service centre ?
dixitshantanu55So I was playing PUBG and I only use my right trigger (dual partition mode) while my left trigger is turned off.
I was experiencing some instances where even if I tapped my right trigger, it didn't work. So I began trying to troubleshoot what's up with it. I went to the slide settings of AirTriggers and I noticed that my right trigger flickers alot when I slide my finger through it. My left trigger is absolutely fine and smooth as I slide through it. But the right trigger flickers alot when I slide.
If I slide my right trigger from a little back from a different angle, it works smoothly as well. But it flickers when I slide my finger on it normally.
I have tried clearing the cache data from both Armoury Crate app and the AirTriggers sub app. It didn't solve anything.
What should I do?
Right Trigger Issue
