12-03-2020 02:20 AM - last edited on 01-16-2024 04:20 PM by ZenBot
12-03-2020 11:58 PM
Chris LWell glad to see a fan,well if that will ease your worry,I use it from 80% to 20-40 aka until I get home,and I keep it on slow charginghttps://zentalk.asus.com/en/discussion/comment/137260#Comment_137260
I have also noticed how hot it gets when charging, significantly hotter than my OnePlus 8 that charges at the same 30w. I thought it was an issue but everyone says it's normal, but as long as I'm not in a rush I tend to leave it on slow charging so it doesn't get so hot. It also gets super hot on the back when I game which I thought was a problem, but the vapor chamber is letting the heat out where the vent is and when I compare how hot it gets to my other phone it's actually quite similar. The OnePlus phone vents heat through the screen though, and it literally burns my finger if I run COD maxed out lol.
I have also watched battery drain tests where people say the ROG Phone is the coolest on the outside, but they're measuring the temp of the screen with an infrared thermometer and most phones try to vent a lot of heat through the screen while this phone uses the back. I hope that this doesn't happen again, I may just turn it off myself if it goes below 10% and I am not near a charger.
Other than the issue I had last night, using this phone has been a joy. It breezes through everything I throw at it and the battery usually performs amazingly. I hope they continue to make a new one every year, I also hope they release it in my country faster lol it took two months and I was so impatient. I ordered it as soon as I saw it was available.
Thanks for replying!
12-04-2020 05:36 AM
12-07-2020 10:01 AM
12-10-2020 03:31 AM
Chris LLuckily for me this never occured even though I have drained my battery to 0 percent a ton times. Maybe a hardware issue and you may want to take it to the service center for a quick check. General thumb rule for a battery is to keep it between 20 to 80 percent all the time. Even though for me the slow and scheduled charging option doesn't work and hopefully would be fixed through FOTAPlease tell us some basic information before asking for help:
- Model Name: ROG Phone 3 (ZS661KS or ASUS_I003D)
- Firmware Version: 17.0823.2009.99
- Rooted or not: No
- Frequency of Occurrence: 1
- APP Name & APP Version (If your issue relates to the app):
Yesterday I had a very long day and was away from a charger for a very long time. The battery eventually died right before I was able to plug the device in, but it didn't boot up quickly after I finally did. I plugged it in literally 60 seconds after the battery died and all that happened for about 30 minutes was a blinking light. The indicator light at the top blinked red non-stop for 30 minutes until the screen finally turned on and showed a 0% charge. During this period of time that I was waiting, the charging brick was cold enough that I don't believe it was charging the device normally. The device is working normally now, but this makes me worry about the device. I love my ROG Phone and I'd buy it again in a heartbeat, but it is important to me that a problem like this is addressed before I would be willing to buy the next ROG Phone that comes out.
Why does this happen? Is there a fix for this? The research I have done shows that this happened in both the ROG 2 and 3 and it has basically always gotten very little attention and no answers. I will of course avoid draining the battery all the way, but I don't want to worry about bricking my very expensive phone because I let the battery die.
Any answers would be fantastic, I just want to know what can be done. If possible, I would also love to know if this is going to be considered when developing the next ROG Phone because this is a big issue. Some people weren't able to use their device ever again after this happened, I just don't want that to happen to me.
Thank you!
Problems with phone after full battery discharge
12-15-2020 07:33 AM
