My rog3 wifi connection problem ..
bserian791
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
When I try to connect with a wifi network.. my phone got stuck.. not able to open the wife settings too.. when i try to power off or restart.. screen is stuck showing restarting.. only force restart option is working
Saifuddin
Zen Master III
Clearly its software , perform a factory reset and make sure you are on latest version
If that doesn't help , then go to service centre and the will flash you full software 😁
bserian791
Saifuddin
Yes bro.. but i tried reset network options in the settings .. now its ok now.. thanks fr ur suggestion bro 😊
Saifuddin
Zen Master III
bserian791
https://zentalk.asus.com/en/discussion/comment/173385#Comment_173385
Always happy to help 😊
