Microphone volume low for ROG PHONE 3
ajayvijay912
Model Name: asus rog 3
Firmware Version: android 10
Rooted or not: not
Frequency of Occurrence: all the time
During every phone call, for the opposite person, my voice is very low. It's been jus a month, a purchased this phone. It really bad that this issue happens in new phone..
Hope asus team give any solution.. thank you.
6 REPLIES 6
Same problem with me
Danishblunt
Hall of Fame I
If you have rooted device find init.d and add:
tinymix 31 23
tinymix 32 27
tinymix 33 27
tinymix 34 27
tinymix 35 27
then you got nice volume.
EDIT:
nvm this was for motorolla specifically. You need to edit system/vendor/etc/mixer_paths_cdp.xml file and look for volumes.
Make sure you're also on the latest update because iirc ASUS had a little to aggressive noise reduction causing some issues with microphone recordings on some devices.
