Battery fast drainage problem
SnRohit
Its been now 1month i buyed asus rog 3 the phone is using up too battery even though im not using much plz solve my problem
Battery drain fast in normal use its run around 3 hours in single charge.
Danishblunt
Hall of Fame I
Turn 5g off. Problem solved
ARP_ASUS
Community Legend II
Hi @SnRohit,
Hi, when you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Make sure your software version is on the latest which is .99
Factory reset your phone once, if not possible you can check if there is any App which you recently installed which may cause this issue.
