Battery Drainage Problem
isdivyapratap
Model Name: Rog Phone 3
Firmware Version:
Rooted or not: No
Frequency of Occurrence: Continuously
xihe
Rising Star II
What's your firmware version? Have you charged to 100% and monitor it? Done factory reset?
AJ1
Rising Star II
isdivyapratap
  1. Model Name: Rog Phone 3
  2. Firmware Version:
  3. Rooted or not: No
  4. Frequency of Occurrence: Continuously
Clean up storage & memory, check in safe mode if it works then fine if not factory reset the phone, disable or uninstall apps causing battery drainage
ARP_ASUS
Community Legend II
Hi, when you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Share your current software version => Check under Settings, System, Software information
