Battery Drainage Problem
- Model Name: Rog Phone 3
- Firmware Version:
- Rooted or not: No
- Frequency of Occurrence: Continuously
- APP Name & APP Version (If your issue relates to the app):
0
Comments
What's your firmware version? Have you charged to 100% and monitor it? Done factory reset?
Clean up storage & memory, check in safe mode if it works then fine if not factory reset the phone, disable or uninstall apps causing battery drainage
Hi, when you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
