Android System battery drain
hamad_baig2
Model Name: CN Version
Firmware Version:.70
Rooted or not: no
Frequency of Occurrence: always
The phone is suffering from android system battery drain. Android system is draining a big chunk of the battery. I don't use netflix and a light a user of youtube. Please help
14 REPLIES 14
Dr_Ram
I am also facing the same problem after this latest update in ROG phone 2.....it seems happening in ORG 3 also.
nationkid
Rising Star II
ROG 2 is suffering from this massively. Seems to be linked between either google or ASUS software in the latest update.
High temperature / CPU usage / battery drain on 2009.47
^ Is the forum post.
sakshamsadana
I own an ROG phone 2 and Facing the same issue since the last update. My phone is not even fast charging after this. Expect to receive a correction update asap.
sakshamsadana
Clear the data of all google apps!
