Android System battery drain
hamad_baig2
Model Name: CN Version
Firmware Version:.70
Rooted or not: no
Frequency of Occurrence: always
The phone is suffering from android system battery drain. Android system is draining a big chunk of the battery. I don't use netflix and a light a user of youtube. Please help
14 REPLIES 14
hamad.baig2
  1. Model Name: CN Version
  2. Firmware Version:.70
  3. Rooted or not: no
  4. Frequency of Occurrence: always
Hey this will happen if u use dual accounts! If u do then delete the second account or user
If not clear the data of all the google apps mainly google play services! (This is the main reason for android system batery drain as this is the core!)
hamad_baig2
I have cleared the data/cache of all google apps but still no luck!
What do you mean by dual accounts
Like using two google accounts on the phone?
Aryan202
Community Legend I
I think this is related to the google play store drain
Try disabling play store maybe till google issues an fix
eqlm2
Rising Star I
hamad.baig2
yes it is
eqlm2
Rising Star I
i am facing the same problem i cant get more than 5H SOT and it is ridiculous
