Always on screen Display issue and pubg issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-30-2020 11:49 PM
Model Name: ROG PHONE 3
Firmware Version:17.0823.2007.47
Rooted or not: Not rooted
Frequency of Occurrence: frequently occurs
APP Name & APP Version (If your issue relates to the app):Pubg mobile and always on screen Display
I brought my rog3 on 28th August and i am facing flickering issue with the always display it sometimes show bright dim. My adaptive brightness is off. And also pubg gameplay not that smooth. It doesn't lag but it's smooth.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-30-2020 11:51 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-02-2020 07:33 AM
Always on display - The brightness shouldn't change as it is by default no option to change.
PUBG - If no lag, under PUBG graphics can you check if the settings are correct even the highest setting the smoothness should be maintained. Also, check if your phone is on X-mode for best performance.
AdminGo to setting => About => Software information.【Version】
17.0823.2007.58
【Model Name】
ROG Phone 3 (ZS661KS)
【Release Date】
2020/08/31
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?
【Release Note】
- Armoury Crate now also supports portrait mode. Added ROG Connect community.
- Enabled Telia VoLTE/VoWiFi in Norway, Sweden and Finland
- Fixed the conflict between Netflix app and System brightness function
- Fixed not able to detect ROG Strix Arion SSD issue from buttom USB port
- Fixed a large difference between the total power consumption items under the battery page and the actual power display in the status bar.
[200828] ROG Phone 3_ZS661KS_WW_17.0823.2007.58
Try to update the above version.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-02-2020 07:51 AM
diptimohapatra000Hey , no need to worry about pubg now, its anyway banned in india 😔Please tell us some basic information before asking for help:
- Model Name: ROG PHONE 3
- Firmware Version:17.0823.2007.47
- Rooted or not: Not rooted
- Frequency of Occurrence: frequently occurs
- APP Name & APP Version (If your issue relates to the app):Pubg mobile and always on screen Display
