Always on screen Display issue and pubg issue
- Model Name: ROG PHONE 3
- Firmware Version:17.0823.2007.47
- Rooted or not: Not rooted
- Frequency of Occurrence: frequently occurs
- APP Name & APP Version (If your issue relates to the app):Pubg mobile and always on screen Display
I brought my rog3 on 28th August and i am facing flickering issue with the always display it sometimes show bright dim. My adaptive brightness is off. And also pubg gameplay not that smooth. It doesn't lag but it's smooth.
0
Comments
My issue is with the always on display it sometimes is very bright and sometimes is very dim. My adapting brightness is off aswell
Always on display - The brightness shouldn't change as it is by default no option to change.
PUBG - If no lag, under PUBG graphics can you check if the settings are correct even the highest setting the smoothness should be maintained. Also, check if your phone is on X-mode for best performance.
Go to setting => About => Software information.
Try to update the above version.
Hey , no need to worry about pubg now, its anyway banned in india 😔
