Blake_ASUS
Hi there,
I'm thinking that that the issue might be the cable.
You are using the TypeC to TypeC cable from the monitor, right?
The Type C port on UX582 is supporting Thunderbolt , and the Type C port on PA279CV is Displayport.
So we need to double check if the cable is supporting such signal.
Or you may try another cable like Type C(laptop) to Hdmi(monitor)
I believe ive tried that but to clarify your saying buy a usb c to hdmi adapter and plug hdmi in monitor?? so usbc plugged into laptop and then hdmi port into monitor?
That seems to defeat the whole purpose of usbc to usbc as one cable and using peripherals from USB on monitor to connect to laptop and monitor to connect to laptop?
The pro arts came with a usbc cable each. those work with my note 20 fine for display, but with laptop to monitor. nope. phone to laptop with usbc, yes as a charger and to connect for downloading files to and from phone. I assume those usbc cables are meant for doing what im trying to do. Plug laptop or computer into monitor and be done. get display and perpherals.
When i went to best buy to pick their brains they said this should just be usbc to usbc and plug and play. I bought a multi adaptor to test this out. its the insignia 7 port usbc hub. the laptop recognizes it when i plug in, works for mouse and extra keyboard, but hdmi from port to monitor. doesn't work. I was going to dongle usbc to hdmi and USB3.0 and compromise but that didnt even work. Best buy said if that dongle does not work then its definitely ASUS issue with how laptop is made and send in for warranty. so i sent in and got back and am at where i started.
Im at the point where if all tech people i talk to say this should be easy plug and play including asus then i think im going to send the monitors and cables supplied by asus to asus and the laptop back to asus. if they cant set this system up they way its advertised to work and get it to work then im just going to escalate it till someone actually admits it cant be done or says heres the fix xyz or heres your $4,200 back sorry for wasting your time.
Any other suggestions? Cables from asus Pro arts should i think work for usbc to usbc if it works from my note 20 plug and play? im going to keep trouble shooting till nov 1st. aprpeciate your help.
