Hi
mishaalwaheed.kThank you for your asking. Kindly refer to the tips below for troubleshooting.
1. Before you try "Factory data reset", I suggest you to try to enter "Safe Mode" first. If wifi works well in "Safe Mode", please check on any disturbance from the installed 3rd party Apps
#How to enter and exit "Safe Mode"
https://www.asus.com/support/FAQ/1005163/2. For "doing network reset", do you mean "Network settings reset" on phone or on the router?
3. Check SMMI test
Calculator> type ".12345+=">SMMI TEST>Single Test>WiFi Test
If it is impossible to access the service center during Covid-19 period, please try Call us:
https://www.asus.com/support/CallUs
