ROG Gaming Center Won't open / Fan stuck in full power
System: Windows 10
Battery or AC: AC
Description: ROG Gaming Center Won't open / Fan stuck in full power
Model: Asus ROG STrix GL703G
Frequency of Occurrence: Always
Reset OS: No
ROG Gaming center won't open at all when I push the key/button on my laptop and the fan is stuck in permanent high speed setting, which is highly frustrating. Computer is fully upto date, but it still won't open. It makes using the system for normal work purposes (gaming aside) very difficult. What are the steps that need to be done to reset or return the ability for the gaming center to open when I click on the button on the laptop. Thank you in advance
RAJU_MSC_MATHEM
Zen Master I
your question is too difficult to answer from my side. let Rog users Might give solutions
Blake_ASUS
Community Legend II
Hello tarek.alameddine, Is you BIOS also updated to the version released in June? https://www.asus.com/Laptops/ROG-Strix-SCAR-Edition/HelpDesk_Download/ Are you able to open Gaming Center through the icon on Desktop or through program file? If you only can't use the keyboard shortcut, please kindly reinstall ASUS Keyboard hotkeys Driver Thank you for messaging us. Have a nice day.
