3 weeks ago
I want to buy the Pro WS W790E-SAGE SE but first I would like to understand the slimSAS ports that this board have.
Two slimSAS, can I connect backplane extenders on it and use up to how many HDDs on it?
Can I use cable extenders?
What is the specification 16i 8i 4i?
In the specs the only information found was:
SlimSAS_1 port supports PCIe 4.0 x4 mode NVMe device
SlimSAS_2 port supports PCIe 4.0 x4 mode NVMe device
Thank you in advance
vini
3 weeks ago
Hello, @viniciuspalma
Thank you for contacting us.
Regarding your inquiry about the slimSAS specifications and connections for the Pro WS W790E-SAGE SE, we are currently in the process of confirming this information.
We appreciate your patience in advance.
3 weeks ago
Upon confirmation, the SlimSAS specification is SFF-8654, and the speed is PCIe 4.0 x 4.
To connect NVMe storage devices, the SFF-8654 (SlimSAS) to SFF-8639 (U.2/3, PCIe 4.0 x4) cable is required.
Additionally, since there is no SATA mode, each SlimSAS can only connect to one U.2 SSD.
