Lag when on battery mode
billvas2003
System: Asus tuf gaming F15
Battery or AC: Battery
Model: FX506HC
Frequency of occurrence: common
Reset OS:
Screenshot or video:
Detailed description:When the laptop is plugged in it works as expected even under heavy load. When disconneting the power cable minor stuttering occurs while just navigating the os. In the armoury crate app performance is selected. What could be the main reason for this problem? Could a built in battery saver from asus throttle the system this bad?
anhquangno1
GPU uses a lot of energy while gaming. So you always need to plug your laptop in in order to play games. That is crucial for all gaming laptops.
Blake_ASUS
Community Legend II
Hi there,
The performance of battery mode is not as good as AC mode.
Please kindly plug in the adapter when playing for stable performance.
