05-19-2019 10:39 AM
05-20-2019 11:42 PM
05-21-2019 05:54 AM
Selena_ASUS posted on 2019/5/21 01:42 Hi lcsamartins Good dayWell, it says 29% of app usage on the first image with the graphic, but the individual apps shown on the other screen don't add up. There's always a big difference there. I replaced the battery because of the drain, but the problem persisted. I found a reliable place to do it, and they got me another official battery. It seemed to get a little better with the new battery, but the drain is still there. The drain happens in standby mode, and also happens if I use the phone. As I said, it's even difficult to tell the difference, the battery drain looks the same whether I use it or not.
