[HELP] ROG GU502GU can't fix Realtek audio drivers
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-24-2021 02:00 PM
System: Windows 10
Battery or AC:
Model: ROG Zephyrus M GU502GU
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
Hi, I've been fighting to get my audio sound to work but I'm close to giving up. I've tried the official realtek drivers from realtek website, but the headphones won't work, only the integrated speakers. I've already tried all the obvious fixes that you can find on all the forums, including uninstalling the old drivers, checking the sound control panel etc... When I try to install the drivers from the GU502GU Asus support, I have no output sound at all. I've tried lots of drivers from various websites, none will work. I've updated all my other drivers, including the last version of the BIOS. I don't know ho to fix this as I'm running out of otpions. If you have any suggestion that would be really helpful.
Thanks
Louis
Battery or AC:
Reset OS:
Thanks
Louis
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-30-2021 12:05 PM
I am having same problem with my Zenbook 14. and have tried all of the fixes on line, nothing works to get the audio jack on the side to output to headphone or speaker. need solution
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-01-2021 01:19 AM
jlawson01my laptop came with Realtek HD audio device and yesterday I upgraded Device driverI am having same problem with my Zenbook 14. and have tried all of the fixes on line, nothing works to get the audio jack on the side to output to headphone or speaker. need solution
6.0.9132.1 WHQL ..if you want I will share the link so that you can download and install it ,
I think this version is not available in asus support site.
- « Previous
- 1
- 2
- Next »
