GL502VS Replacement Battery
mrbibs350
System: GL502VS
Battery or AC: C41N1531
My original ASUS battery died after 100 cycles in 2018. I replaced with with a cheap offbrand battery as I couldn't find an original ASUS to replace it with. It died in 3 months after 25 cycles. My system only works when plugged in now and I'd really like to have a working battery.
Is there ANYWHERE I can get an ASUS brand C41N1531 that has a remote chance of working?
Blake_ASUS
Community Legend II
Hi there,
I would suggest you to contact our local team, they can help to check the availability in the region.
If they still have the spare part, you can send in the laptop to service center to get it replaced.
