Hi there,
Do you remember having any of the issue before you do any update?
There might be firmware update failed on your laptop, and reset can not fix it.
And it would be quite hard to dig in which update fail at this moment.
Please try to update BIOS and reinstall KB firmware, ASUS System Control Interface, and Armoury Crate.
ROG Strix SCAR 15 G533 - SupportIf it still doesn't work, I would suggest you to send the device to our service center.
Sorry for the inconvenience caused.
