FLOW X13 2021, which USB C port works as DisplayPort?
ARog2
System: Flow X13
Model: GV301QC-K6133T
OS: Microsoft Windows 10 Pro
Version: 10.0.19044 N/A Build 19044
BIOS Version: GV301QC.409, 2022-01-27
Detailed description: The device is from Germany, which USB C port works as DisplayPort?
Bought a USB C hub (Brand: Novoo) and tried to connect the left and right USB C ports and the results are the following: Left USB C port: the mouse, keyboard and Bluetooth headset, charging are not working and the dual external monitors are not working.
Right USB C port: the mouse, keyboard and Bluetooth headset, charging is not working (due to German SKU) and the dual external monitors are not working.
Both monitors are working, USB C hub is working (connected to Thinkpad T14, charging, dual external monitors, mouse, keyboard and Bluetooth headset).
What could the issue be? Windows OS, USB C ports, firmware or drivers?
12 REPLIES 12
GEEK_ASUS
Rising Star II
Hi there,
If updating BIOS and driver could not resolve the issue.
You may consider reset the system.
Please ensure your important data is backup.
Or I would suggest contact service center to do further inspection.
ARog2
hello, hello,
just want to double-check, when you say to reset the system, you mean to reinstall windows 10 correct?
Thanks in advance.
GEEK_ASUS
Rising Star II
Hello,
Because the other function of your PC is fine, I am wondering it's setting issue.
Therefore I am thinking of try reset Windows first.
[Windows 11/10] How to reset the PC and keep my personal files | Official Support | ASUS GlobalIf you would like to reinstall Windows 10, that's also ok.
But no matter which way,please ensure your important data is backup.
ARog2
Hi there,
it seems like the usb c hub (Novoo 12 port hub) is not compatible with flow x13. I manage to get hold of another USB C hub (HDMI, VGA, DVI, USB) and connected that to either USB C port and it worked, the ports worked as DisplayPort. With the 4 ports USB C I can only connect one monitor at a time.
With that, I can assume the USB-C ports on my Flow X-13 can work as a DisplayPort, correct? or could it be a problem with the ports so I should send in the laptop for service?
Do you have any recommendations for what USB C hub I should get?
Thanks in advance.
GEEK_ASUS
Rising Star II
Hi there,
Thanks for your cross check.
Yes, Flow X-13 USB-C can work as DisplayPort.
You may check below if there is dock that fit your need.
All series|Docks Dongles and Cable|ASUS Global
