FA506IV Audio / Video stuttering problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-11-2021
10:42 AM
- last edited on
01-16-2024
01:40 AM
by
ZenBot
Battery or AC: Both
Model: FA506IV
Frequency of occurrence: after 4-5 hours
Reset OS: No
Screenshot or video: Attached
Detailed description:After running my system for 4-5 hours any video/audio application is suffeering from stuttering every couple of seconds. Video and audio stutters. Does not matter if it is an on-line video / audio combination or a video / audio played using for VLC.
The stutter goes away after rebooting the system but it comes back after 4-5 hours.
It is a huge problem because it makes impossible to use the laptop for Business Calls using Teams because there is no warranty that the next call will not suffer from audio / video stuttering issue.
Tried to change the drivers for NVIDIA and AMD cards and the AMD Chipset but it did not help. Bios is updated to the latest available version.
If anyone can help I would be gratefull.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-11-2021 03:14 PM
You need to install it and when asked about keeping settings and clean install You need to select clean install and unselect to keep settings.
After reboot You need to relaunch the installer so it completes the installation process.
After that it seems the problem is gone.
It seems that from time to time Windows Update would install an older driver that is not compatible with Adrenalin Software and can cause this kind of problems.
The driver was usually installed automatically so it was easy to miss when it installed itself.
It seemed like a typical Windows Update procedure.
Can anyone with this kind of problem confirm that this solution helps?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-11-2021 09:23 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-12-2021 11:38 AM
kubiastySo I've allowed the operating system to install the invalid drivers. Then I've blocked the driver updates again.I'm afraid that after keeping the computer for the night, idling, and trying to play something at the morning the problem returned. So my question is still on. Anyone got his method to solve this problem?
Then I've decided to give the Non-WHQL driver a shot.
I've installed Non WHQL Radeon Software Adrenalin-2020 21.6.2 Win10-64Bit June29.
8 hours of running and work and the problem does not seem to occur.
I will report if this one solves the issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-19-2021 04:44 AM
