asus tyf fx505dt battery drains too fast
System: ryzen 5 with gtx1650
Battery or AC: battery
Model: fx505dt
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:battery drains too fast not working even 1 hour random lags occur boot time get from 5.8 to 7.8 also i dont have a nearby care centre makes my work even harder
Blake_ASUS
Community Legend II
Hi there,
Please kindly check if your BIOS and Windows are up to date.
and which mode did you set in Armoury Crate?
What kind of program are you using?
you may check by battery report or task manager to see if there is any program consuming power more than you exptected.
