08-29-2023 10:54 AM
I have purchased a ASUS Ai Mesh AX-WLAN System ZenWiFi XT8 (2-in-1 Mesh Access Point Set, AX6600 WiFi 6) pack that i'm unable to register on ASUS site. I i tried using the S/N found in each AP but the ASUS site replies
"Serial number incorrect!" even though it recognizes the device.
Unfortunately i have dropped the package that contains the set.
Is there any way to find the correct SN of the set
#ZenWiFi XT8, #2-in-1
08-29-2023 11:27 PM
Hi @csyrmas ,
based on your issue, may I ask whether you cannot find the ZenWiFi XT8 product serial number?
Have you check the label on the product?
You can refer to the following link.
Official Support | ASUS Global
09-12-2023 06:15 PM
I’m in the same boat mate
09-06-2023 10:32 AM
