WHEN HTTPS ENABLE THAN ASUS WEB ACCESS SLOW
Subha7455
When I enable the https option from the access website of my Asus router, the access website of my router is opening slower than before. Is this happening to everyone or just me?
Aureliannn_ASUS
Hi @Subha7455 ,
Thank you for your question.
To help us better assist you, we recommend that you try the following methods:
  1. Use a wired connection: We recommend that you use a network cable to directly connect your computer to the router to eliminate the impact of wireless network interference. This will allow you to access the web management interface more stably.
  2. Clear browser cache: Please clear the cache and cookies of the browser you are using. This helps ensure that you load the latest web page content each time you visit, avoiding the impact of old data.
  3. Try a different browser: If the problem persists, we recommend that you try using other browsers (such as Chrome, Firefox, Edge, etc.) to access the web management interface. Different browsers may have different performance.
  4. Turn off unnecessary services: You can temporarily turn off some infrequently used functions on your router, such as UPnP, remote management, etc. These functions may consume system resources and affect the speed of the web management interface.
  5. Adjust QoS settings: If your router has QoS enabled, you can try to increase the priority of the web management interface. This helps ensure that the web management interface gets enough bandwidth.
  6. Factory reset: If none of the above methods solve the problem, we recommend that you restore the router to its factory settings. This can help rule out problems caused by software configuration errors.
[Wireless Router] When Standard Reset Isn’t Working: Hard Factory Reset - Models list | Official Sup...
[Wireless Router] How to upload your own certificate(HTTPS/SSL) on ASUS router | Official Support | ...
