07-09-2025 06:49 AM - edited 07-09-2025 02:26 PM
Trying to add the node pictured to my system at home to cover some more area towards the front of the house. I have 2 XT8 (same, other than the originals are white) units already that have been up and running well for a month or so, using a wired backhaul from where my modem/main unit are in the utility room to the node in my office. I put this new node (pictured) near either of those units, it gets detected, seems to connect and then almost immediately goes offline and never comes back. I am trying to use a wireless backhaul on this unit. This has happened both when I've connected to the primary unit, or to the existing node. I have reset via the reset button and tried about 10 times over the last week with the same results. I did connect this unit to the router via ethernet and that seemed to work and connect, but I don't know what to do after that, if I disconnect the cable I lose connection and can't get it to connect via wireless. I do not have an ethernet cable run to where this unit needs to go. Do I need to do a different type of reset, I think there is a hard reset, or factory reset or something that involves the WPS button and power cycling?
Anyway, set-up seems to work like it should and then just drops and won't reconnect. Light is solid red shortly after setup
07-14-2025 06:53 PM
Hi @mkvien ,
thank you for explaining in detail the issue you’re facing when trying to add a third ASUS ZenWiFi XT8 node to your existing AiMesh network.
Regarding the issue you’re experiencing while adding a third ASUS ZenWiFi XT8 node to your existing AiMesh network, we understand you want to ensure it connects reliably in wireless backhaul mode.
We suggest trying the following steps to help verify and address potential issues:
If you continue to experience the same issue after completing these steps, we suggest sending the router to official service center for further assistance.
