01-04-2025 06:46 PM
First post here so bear with me if I miss anything. Since purchase, my RT-BE92U has been plagued with the same issues others have posted here. Up until the new firmware version dropped, I was having constant problems with network stability. I am currently running the latest firmware version (3.0.0.6.102_37435) and a lot of the issues seem to have been resolved except for one. Before the firmware update, I was seeing intermittent thermal zone errors in the system log. Since applying the update, I am consistently getting the following errors that appear every 3 seconds exactly:
Jan 4 18:29:52 kernel: read_bpcm_reg_direct_keyhole: Wait for completion failed, devAddr 0x3, offset 24, idx 2
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get RAIL 0 temperature, ret=256
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get temperature, ret=-1
Jan 4 18:29:52 kernel: thermal thermal_zone0: failed to read out thermal zone (-1)
On occasion, the errors coincide with a drastic decrease in wireless network performance. Under normal conditions, when connected to the 6GHz network, my wireless network download speed averages around 1100Mbps. This will drop to a nearly unusable 2-3Mbps. The 2.5GHz and 5GHz networks also see a decrease in speed to around the same 2-3Mbps. Wired clients seem unaffected. Once I perform a hard reset to the router, it seems to correct the speed issue for a while, but the thermal zone errors continue to persist. This seems to happen anywhere from once a week, to every day. Performing a hard reset isn't something I want to nor should have to keep doing to correct the issue every time it happens. Please let me know if there is anything else I can do to stop this from happening. I am getting very close to returning this router and exchanging it for a different brand. Thanks.
03-17-2025 11:28 PM
Hi @senyk92 ,
did you report the issue through the system at the time it occurred?
If so, please send us a private message with your report email, report time, and MAC address, and we will coordinate with our team for further verification. Thank you for your cooperation!
03-18-2025 01:46 AM
Installed 37506, this appears to have resolved core 3 being at 100% however log file continues to be stuffed with DEAUTH and kernel: Dump pkt: messages. As in 1000s of them 24x7. Log file rendered useless as you cannot sift through it all to make any sense.
Mar 18 04:47:50 kernel: Dump pkt:
Mar 18 04:47:50 kernel: 0000: aa aa 03 00 00 00 08 00 45 00 01 7f 00 00 40 00
Mar 18 04:47:50 kernel: 0010: 40 00 02 11 c5 df c0 a8 01 33 ef ff ff fa ed 3e
Mar 18 04:48:16 kernel: Dump pkt:
Mar 18 04:48:16 kernel: 0000: aa aa 03 00 00 00 08 00 45 00 01 7f 00 00 40 00
Mar 18 04:48:16 kernel: 0010: 01 c9 c0 a8 01 94 b6 ec d8 93 13 30 58 5c 28 ea
Mar 18 04:49:10 kernel: Dump pkt:
Mar 18 04:49:10 kernel: 0000: aa aa 03 00 00 00 08 00 45 00 01 7f 00 00 40 00
Mar 18 04:49:10 kernel: 0010: 01 9c c0 a8 01 df d8 94 d8 94 00 10 d4 69 47 b4
Mar 18 04:50:02 kernel: Dump pkt:
Mar 18 04:50:02 kernel: 0000: aa aa 03 00 00 00 08 00 45 00 01 7f 00 00 40 00
Mar 18 04:50:02 kernel: 0010: c0 a8 01 9c 10 7c 61 ef 4c 20 c0 a8 01 01 bf 81
Mar 18 04:53:14 kernel: Dump pkt:
03-19-2025 01:45 PM
Hey @Aureliannn_ASUS ,
I'll send you a private message, sending feedback directly through the admin portal creates a bootloop every 3 min or less and the feedback fails to send ( Screenshot attached ), I'm not sure who within Asus QA'd this device and signed off, but collecting info during instability and rebooting has been challenging and im suprised this wasnt caught pre-prod testing.
a month ago
I put my BE92U router back on line a week ago following a 37506 firmware update. Seems to have resolved many issues but still showed lots of entries in the system log. Last night it auto-installed a 37523 firmware update, however, Asus does not list 37523 on its update site. Did I inadvertently receive a "beta" update? Should I restore it to 37506?
a month ago
@WK my BE92U is also offering this firmware. I'd personally like to know what it's supposed to fix before installing it. It does not appear to be a beta.
