RT-BE92U Persistent Thermal Zone Faults
RicoSuave
First post here so bear with me if I miss anything. Since purchase, my RT-BE92U has been plagued with the same issues others have posted here. Up until the new firmware version dropped, I was having constant problems with network stability. I am currently running the latest firmware version (3.0.0.6.102_37435) and a lot of the issues seem to have been resolved except for one. Before the firmware update, I was seeing intermittent thermal zone errors in the system log. Since applying the update, I am consistently getting the following errors that appear every 3 seconds exactly:
Jan 4 18:29:52 kernel: read_bpcm_reg_direct_keyhole: Wait for completion failed, devAddr 0x3, offset 24, idx 2
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get RAIL 0 temperature, ret=256
Jan 4 18:29:52 kernel: thermal thermal_zone0: Failed to get temperature, ret=-1
Jan 4 18:29:52 kernel: thermal thermal_zone0: failed to read out thermal zone (-1)
On occasion, the errors coincide with a drastic decrease in wireless network performance. Under normal conditions, when connected to the 6GHz network, my wireless network download speed averages around 1100Mbps. This will drop to a nearly unusable 2-3Mbps. The 2.5GHz and 5GHz networks also see a decrease in speed to around the same 2-3Mbps. Wired clients seem unaffected. Once I perform a hard reset to the router, it seems to correct the speed issue for a while, but the thermal zone errors continue to persist. This seems to happen anywhere from once a week, to every day. Performing a hard reset isn't something I want to nor should have to keep doing to correct the issue every time it happens. Please let me know if there is anything else I can do to stop this from happening. I am getting very close to returning this router and exchanging it for a different brand. Thanks.
225 REPLIES 225
I'm not sure if this release fixed their issue or they gave up.  I was considering a Netgear RS500 but although it has a VPN server there's no client capability which is a deal breaker for me.  So my only real option is staying with Asus but moving to a different model.  I don't know if I'm just exchanging trouble or what.    I'm pretty much snake bit by this router and don't have a lot of confidence in it.
