12-10-2024 10:35 AM - edited 12-10-2024 10:37 AM
I've had the RT-BE92U for a few weeks now and a couple of times a day it simply stops routing DNS WAN traffic and the Wi-Fi networks also stop routing. All Internet access grinds to a halt because of this. Sometimes it returns to normal on its own but today it was so inconvenient that I got it to reboot via the web UI. It's then fine again for several hours.
It's like the unit itself enters some kind of semi-hung/crashed state. I'm thinking there's some kind of memory leak or that the RAM capacity is insufficient. It runs for several hours and then begins going faulty.
I am 26 years into an advanced IT solutions architecture/engineering career covering pretty much all kinds of infrastructure. So, the most I'm guilty of is not trying the basics.
I am able to ping externally, however I tend to find that I cannot get DNS traffic to pass and that includes direct queries of external DNS services, e.g. 8.8.8.8 (I can ping this guy).
The Wi-Fi networks can't even reach the router itself. I have to go to my wired laptop to engage with the router. The router web UI responds normally. The system log just seems to show either long pauses between log entries or errors about wireless client disconnects.
This kind of error seems to be common in the log just now:
kernel: WLC_SCB_DEAUTHENTICATE_FOR_REASON err -30
kernel: WLC_SCB_DEAUTHORIZE error (-30)
Could be red herrings but they always seem to be around when the crashes happen.
I have a lot of smart devices. It says I have a total of 54 clients but the vast majority of those will generate very little traffic.
I use Sky Stream. So, there can be a lot of throughput there. I also watch a lot of Twitch. Again a lot of data passing through for that. Nothing I wouldn't expect this router to handle though.
I have AiMesh up and running with two nodes.
I use the Time Machine backup capability with a USB drive attached. There's an hourly backup.
I have the AiProtection turned on. DoS protection enabled.
I also have the DNS over TLS enabled opportunistically but I've tried putting this off and it doesn't help.
I just fear that the hardware spec isn't able to handle the workload.
It just seems like the firmware isn't stable enough yet. I need to decide if I should be returning this or just be patient and wake for the next firmware updates.
Anyone else with this router experiencing issues despite factory resetting?
Solved! Go to Solution.
2 weeks ago - last edited 2 weeks ago
6Ghz band is the issue. Either turn it off completely or lower the tx power lower then Performance to Good, Balanced or Power Saving.
Since the last 2 firmwareupdates on the router of my dad, there was no losses of WLan or internet!
