RT-BE92U - On-going random losses of Internet/WAN access
AndrewMcN
I've had the RT-BE92U for a few weeks now and a couple of times a day it simply stops routing DNS WAN traffic and the Wi-Fi networks also stop routing. All Internet access grinds to a halt because of this. Sometimes it returns to normal on its own but today it was so inconvenient that I got it to reboot via the web UI. It's then fine again for several hours.
It's like the unit itself enters some kind of semi-hung/crashed state. I'm thinking there's some kind of memory leak or that the RAM capacity is insufficient. It runs for several hours and then begins going faulty.
I am 26 years into an advanced IT solutions architecture/engineering career covering pretty much all kinds of infrastructure. So, the most I'm guilty of is not trying the basics.
I am able to ping externally, however I tend to find that I cannot get DNS traffic to pass and that includes direct queries of external DNS services, e.g. 8.8.8.8 (I can ping this guy).
The Wi-Fi networks can't even reach the router itself. I have to go to my wired laptop to engage with the router. The router web UI responds normally. The system log just seems to show either long pauses between log entries or errors about wireless client disconnects.
This kind of error seems to be common in the log just now:
kernel: WLC_SCB_DEAUTHENTICATE_FOR_REASON err -30
kernel: WLC_SCB_DEAUTHORIZE error (-30)
Could be red herrings but they always seem to be around when the crashes happen.
I have a lot of smart devices. It says I have a total of 54 clients but the vast majority of those will generate very little traffic.
I use Sky Stream. So, there can be a lot of throughput there. I also watch a lot of Twitch. Again a lot of data passing through for that. Nothing I wouldn't expect this router to handle though.
I have AiMesh up and running with two nodes.
I use the Time Machine backup capability with a USB drive attached. There's an hourly backup.
I have the AiProtection turned on. DoS protection enabled.
I also have the DNS over TLS enabled opportunistically but I've tried putting this off and it doesn't help.
I just fear that the hardware spec isn't able to handle the workload.
It just seems like the firmware isn't stable enough yet. I need to decide if I should be returning this or just be patient and wake for the next firmware updates.
Anyone else with this router experiencing issues despite factory resetting?
138 REPLIES 138
In order for me to clear these errors on my router.  I turned off the 2.4 band and the 5 Ghz bands on the main router but left them on for the AImesh  routers.  I now seam to have a stable connection.
AndrewMcN
It’s not that simple. The implementations can choose specific licensing. Samba changed from GPLv2 to GPLv3/LGPLv3 (or later) and they require that any non-individual sign their Samba Developer’s Declaration. It caused quite the furore when it first happened.
GPLv3 includes explicit patent provisions that require distributors to license essential patents under terms that allow everyone to use the software freely.
GPLv3 requires distributors to provide installation information. Some companies avoid using GPLv3 code in IoT or embedded systems because of this requirement.
It means that if you use Samba versions under GPLv3, you can’t keep any secrets. For example, this led to Apple developing its own private implementation of the protocol after years of using Samba.
These issues also create complications for use in China.
TonyGinSLC
Wow. Didn't realize the change in licensing.  Sounds like a total debacle . Still seems like no licensing is required for open-source samba. Either way Ausus needs to upgrade SMB on their router. Full of vulnerabilities.
JKnat
I too have a problem with this router and the latest firmware 37435. My RT-BE92U randomly restarts itself (I did not schedule auto-restarts). This happened on the previous firmware as well. Disappointing to see there were no stability fixes in the changelog.
JKnat
Also, I should add that in my system logs under the web GUI, I see many "failed to get temperature" errors and related messages.  It pops up every second, this might have something to do with the restarts?
