RT-BE92U - On-going random losses of Internet/WAN access
AndrewMcN
I've had the RT-BE92U for a few weeks now and a couple of times a day it simply stops routing DNS WAN traffic and the Wi-Fi networks also stop routing. All Internet access grinds to a halt because of this. Sometimes it returns to normal on its own but today it was so inconvenient that I got it to reboot via the web UI. It's then fine again for several hours.
It's like the unit itself enters some kind of semi-hung/crashed state. I'm thinking there's some kind of memory leak or that the RAM capacity is insufficient. It runs for several hours and then begins going faulty.
I am 26 years into an advanced IT solutions architecture/engineering career covering pretty much all kinds of infrastructure. So, the most I'm guilty of is not trying the basics.
I am able to ping externally, however I tend to find that I cannot get DNS traffic to pass and that includes direct queries of external DNS services, e.g. 8.8.8.8 (I can ping this guy).
The Wi-Fi networks can't even reach the router itself. I have to go to my wired laptop to engage with the router. The router web UI responds normally. The system log just seems to show either long pauses between log entries or errors about wireless client disconnects.
This kind of error seems to be common in the log just now:
kernel: WLC_SCB_DEAUTHENTICATE_FOR_REASON err -30
kernel: WLC_SCB_DEAUTHORIZE error (-30)
Could be red herrings but they always seem to be around when the crashes happen.
I have a lot of smart devices. It says I have a total of 54 clients but the vast majority of those will generate very little traffic.
I use Sky Stream. So, there can be a lot of throughput there. I also watch a lot of Twitch. Again a lot of data passing through for that. Nothing I wouldn't expect this router to handle though.
I have AiMesh up and running with two nodes.
I use the Time Machine backup capability with a USB drive attached. There's an hourly backup.
I have the AiProtection turned on. DoS protection enabled.
I also have the DNS over TLS enabled opportunistically but I've tried putting this off and it doesn't help.
I just fear that the hardware spec isn't able to handle the workload.
It just seems like the firmware isn't stable enough yet. I need to decide if I should be returning this or just be patient and wake for the next firmware updates.
Anyone else with this router experiencing issues despite factory resetting?
138 REPLIES 138
Did you try using the built in feedback tool in the web interface and report the issue? I was told to do that and I think they need more examples and use cases on what is going wrong with the routers or they won't know how to fix it.
You can also try the beta firmware I linked but so far, following these steps seems to make it more reliable.
The beta firmware is a bit of a problem. I can't operate the router physically, but only via remote maintenance because the device is 500km away at my father's.
zane1
Pretty disappointing issue, can't believe there's not a public fix for this. Bought this router a few days ago as a supposed major upgrade over a 5 year old, low-end nighthawk router -- who would have thought the legacy router would have better stability?
When it works it works, but the same devices keep disconnecting several times a day and as others reported 1 CPU core is constantly under heavy load. Firmware version is 3.0.0.6.102_37435-gdd27f25_1059-g807f7_BB0B.
How the heck is the current best solution to jump through hoops to get support to give a beta version of the firmware?
bobo138
Firmware 37803 , wifi more stable now without disconnecting so far(1hour). Memory usage still high at 725 with nothing on.  Temp read error came back. Plus they fix high single core usage to 3 core at always 100%.
I have firmware 37435 and there is not hight CPU usage, only high RAM with 78%:
And there are random some Errors in the Syslog:
