DSL-AX82U
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-28-2023 04:51 AM
Im looking for the part number for my power adaptor for Asus DSL-AX82U Router ?
I have mislaid my original charger and therefore looking for a replacement unit. Most of the google searches relay to RT-AX82U which i believe is a different charger due to the input connector size
I have contacted Asus directly but they are unable to supply the part number due to intellectual rights.
If anyone owns this unit and could check, that would be great.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-28-2023 07:36 PM
From the specs page you need a DC 12 V, 2.5 A AC adapter:
https://www.asus.com/networking-iot-servers/modem-routers/all-series/dsl-ax82u/techspec/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-28-2023 07:57 PM
Something like this hopefully has the correct fitting tip:
12V 3A AC Adapter Power Supply Charger [12 Volts 3 Amps Regulated Switching Power] with 11 Interchangeable DC Plug for 500mA 600mA 700mA 800mA 900mA 1000mA 1500mA 2000mA 2500mA 3000mA Equipment https://a.co/d/buI2ndP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-29-2023 01:49 AM
Hi @bourbon74 ,
based on your issue, you can refer to the following picture.
DSL-AX82U - Tech Specs|Modem Routers|ASUS Global
