Can't find AdGuard / ad blocking DNS setting
j-lamar
Hi, while setting up my recently purchased ZenWiFi AX (XT8) system, I enabled a setting somewhere -- in either the Web GUI or the iOS app -- to actively block advertisements from showing up in web traffic.
It's working great, but in case I want to disable that ad blocking feature, where is it? I thought it had something to do with DNS and possibly AdGuard, but I cannot locate a setting anywhere.
Thanks!
1 ACCEPTED SOLUTION
Accepted Solutions
jzchen
Zen Master II
Under Advanced Settings -> WAN -> (default tab) Internet Connection
Under heading WAN DNS Setting - DNS Server click the "Assign" button.  Default is the top option, which is to get DNS server assigned by your ISP.
jzchen
Zen Master II
