Friday
Hello,
In one of our computers we have an ASUS PCE-AXE5400. The Router is a Fritz!Box 6591 so 5 Ghz & 2,4 Ghz only. The PC is on the floor, about 4 meters away from the Router and at right angles to it so the Aerials are "Side On" to it. The connection shows as Wi-Fi 5, 160 MHz, WPA2, 2 x 2, 11v, MU-MIMO. The down max's at 650 Mbit/s whereas our Macs show a fixed 866 Mbit/s. The aerials are set in the standard "V" configuration. Is it better to have them in the "L" configuration?
Sunday
Usually instructions have a recommended position image, or otherwise it's probably best to try different ones and see which is faster (trial and error).
