08-30-2025 07:24 AM - edited 08-30-2025 07:26 AM
Does the ASUS GT-BE98 Pro router not support "Arp Binding" in the latest firmware version? I already searched a lot and did not find this option. If you really don't have this option can it be added to future updates?
Solved! Go to Solution.
08-31-2025 08:37 AM
ROG routers such as the GT-BE98 Pro are also covered on the ROG forums. If you are on the fence about purchasing because of this specific question, it can also be asked over there. There's also a suggestions thread...
I do believe the GT-BE98 Pro does support this, which I believe allows static IP assignment outside of the DHCP server range?
Say you set DHCP server to assign 192.168.50.50 - 192.168.50.254. Then you want to assign static IPs 192.168.50.2 - 192.168.50.49...
https://rog-forum.asus.com/t5/gaming-routers/bd-p/NW_Routers
08-30-2025 06:09 PM
The simple answer is it has that and much more. I use two in MLO mesh.
08-30-2025 06:48 PM
Where is the Arp Binding setting? I've looked through a lot of settings and haven't found it, but since this router has a lot of settings, I may not have looked in the right place.
08-30-2025 06:57 PM
Go to DHCP reservation in LAN settings in the web GUI. DHCP server>manually assigned IP.
08-30-2025 07:34 PM - edited 08-30-2025 07:39 PM
Arp Binding and IP DHCP reserve are not the same, they are different settings.
