01-24-2025 03:25 PM - edited 01-24-2025 03:41 PM
5g wifi is not visible. if the channel is even below 100 (auto)
5g wifi is visible only when manually set below 100 channels
01-25-2025 12:45 AM
I had such problems with 5g wifi recently on my old router (AC68U). then i was using firmware asus merlin. I restarted the router once. 5g wifi disappeared. but I router restarted before and there was no such problem. I put a manual channel then, you see
01-25-2025 01:41 AM
I use Jiri Technet Network Analyzer app to look at WiFi availability. Maybe it or something similar can help you determine whether it is the router not sending signal or the device problem...
01-25-2025 03:36 AM
I think the problem is in the firmware
02-04-2025 05:42 PM
Hi @sozunude ,
we apologize for the delayed response due to the recent holiday. Thank you for your patience.
Regarding the issue you are experiencing, we would like to confirm the following:
If the issue remains after these steps, please submit a system report so our technical team can further analyze and verify the problem.
You can submit a feedback form Web GUI (http://www.asusrouter.com).
1.Connect your device to your router and log in to Web GUI(http://www.asusrouter.com)
2.Find “Administration,” and tap “Feedback”
3.Fill in your region, email (required field), ASUS Service No./Case No.(not required),Select the feedback problem and description.You can also write down comments/suggestions. More details might help us to analyze the issue you have encountered in a faster and more efficient way.
4.Read the agreement and click “I agree.”
5.Tap “Send” to submit your feedback.
Then provide the product serial number, the time of submitting the issue report, the email used for filling out the issue report, and the time when the issue occurred via private message.
01-25-2025 03:35 AM
Really guys.. this thing you couldn't figure out .. it's not your phone it's you messing around with your modems/routers ,thinking you no wat your doing... Some of yous who seen the 5g before but no longer see it... You definitely messed with the wifi app settings ... Stop messing around with your settings if u don't no wat ur really doing... It can drive a guy crazy lol trust me , I no from experience.. but since I'm here.. any of yous having problems once you downloaded the newest update they released not long ago .. especially with charging glitching off and on from both ports every 7 to 10 secs,screen seems different to
