TPM problem
pavliks
I have a issue with my League of Legens. It says that I need to enable the TPM, so  I've watched some tutorials in youtube, and all the tutorial says that I need to click the PCH - fw Configuration. But, in my bios (advanced) it only has PCH Configuration and PCH Storage Configuration. What seems to be the problem?
I have intel i5-6600k and Z170-A motherboard
Jiaszzz_ASUS
Hello @pavliks
Thank you for reaching out to us.
The settings in the BIOS can vary depending on the BIOS version, motherboard model, and installed hardware.
According to the specifications for the Z170-A, it provides a 14-1 pin TPM connector.
May I ask if you have connected the TPM module according to the installation instructions?
Regarding TPM requirements for the game, if TPM is not enabled, are you unable to run the game?
We recommend adjusting your hardware configuration or settings based on the game’s requirements.
