B650 Motherboard - no networking hardware
CJRC
I have just installed Windows 10 on a newly built  PC with a B650 M A AX 11  Motherboard. Everything seems OK but when I try to set up the internet connection I get the message   "Windows did not connect any networking hardware.".
Could anyone suggest what might be wrong ?
Jiaszzz_ASUS
Hello, @CJRC
May I ask if you are currently connected via LAN or Wi-Fi?
Have you checked the user manual for the correct connection?
We recommend consulting the following two FAQs for further troubleshooting:
[Motherboard] How to fix the cable network problems of Motherboard – Troubleshooting
[Motherboard]Troubleshooting-How to fix Motherboard WI-FI connect problem
If necessary, consider updating the BIOS to the latest version 2214 and clearing CMOS to see if it resolves the issue.
