Asus H110T CMOS reset problem
Anonymous
Not applicable
When I start the computer with this motherboard, I get a message to press F1 to reset the BIOS settings. The problem is that I don’t know the BIOS password. I tried to reset the CMOS using all the methods I found, but it doesn’t work. I even replaced the CMOS battery. Additionally, during the start, I am not able to select the DEL and F2 keys. After displaying the message I mentioned earlier, I can easily select F1.
6 REPLIES 6
Jiaszzz_ASUS
Hello @Anonymous
Could you please confirm if your current BIOS version is the latest version 4212 provided on the official website?
According to the instructions in "How to Configure or Resolve Forgotten BIOS Password/UEFI Password/Boot Password," if you have forgotten your BIOS password, you may need to consider sending it in for service to have the BIOS reflash.
Anonymous
Not applicable
BIOS Ver. 3805
The problem has been solved, the topic can be closed.
Anonymous
Not applicable
The motherboard has an old version of the BIOS.
