01-23-2024 10:11 PM
Hi, I'm looking for info about PA147CDV.
I already found PA147CDV only works with windows (touch or software else..)
But I'm wondering PA147CDV dial also works only Windows.
I think vertical mode will be nicely fit to Apple Music display.
01-31-2024 07:18 PM
Hi @Eoseok ,
the PA147CDV currently only supports the Windows operating system as well as the Dial Control Panel.
You can refer to the following link:
ProArt Display PA147CDV|Monitors|ASUS Global
