12-02-2023 06:26 AM
When I trie to calibrate a HDR preset, like in the video, short before the end of the calibration, I get only a failure popup, "Während des Kalibrierungsvorgangs ist ein Fehler aufgetreten. Bitte beginnen Sie noch eimal von vorn." SDR calibration fine. Any owner of a pa monitor with better results here?
Thanks
12-04-2023 11:29 AM
Installing the X-rite calibration software gives you an update of the driver for the x-rite display, maybe the the only possibility the get the driver update. Not shown in the device manager. Now Asus calibration works.
12-05-2023 10:38 PM
Hi @funjo4870 ,
may i asl whether the pop up error messege still occur?
Please make sure that all the driver is at the latest version.
For calibration setup and operation you can refer to the following link.
