VGA lights and boot lights on
CHI2ALUCARD
NEW PC BUILD/ ALL PARTS
My VGA  and boot light comes on when I turn on my PC, my graphic card is Asus Nvidia GeForce RTX  4070 dual. CPU is a 14th Gen 24-core (intel core i9-14900K)
I HAVE NO DISPLAY, - but if i randomly press the F-keys on my keyboard, it seems to react to the pc either by restarting it... or does nothing... EITHER WAY, I still get no display. both lights
     -VGA
     -Boot
comes on and stays on. all fans on my pc and everything else (led lights) works.
I also notice, the Graphics card (GEFORCE RTX 4070)'s fan spins for a short few seconds when the pc is power on, then stops.  So I know it's got power.
So here's what I have done to diagnose to see where the problem could be.
I have replace and swap the DDR5 ram stick, bot stick and place it in one slot at a time, still no display.
I have also removed the Graphic Card, re-installed it, still nothing.
I have also removed the Graphic Card completely and just plug my HDMI cable directly into the motherboard's HDMI and STILL got no display. both VGA and Boot lights still comes on and stay on.
AND YES, I have also check all connections, all is plug in and snug tight ....
I have also clear the CMOS, still got nothing...
SO - do I need to update my BIOS? if i do, how the heck am I supposed to do that if I can't got no display...
I have order all the parts through NEWEGG.COM through their "build your own PC". let me know if the intel core needs a bios update...... thank for your help.
0 REPLIES 0
