Help my rtx 3080 having red light issue
wassupTobi
My rtx 3080 giving red light blinking issue since today morning as i run Gta V the pc crash & auto restart in some time while the grahics card start blinking red light on it now I thought it was game problem so I reinstalled it but it's still not working & it started to have same problem with other games like cs2 & others less
Aureliannn_ASUS
Hi @wassupTobi ,
based on your question, may I inquire if you are using two 8-pin connectors?
Have you ensured that the power supply is sufficient?
If you have checked the power supply but the red light still illuminates, you can try inserting the graphics card into another computer for cross-testing. Additionally, please confirm that the graphic drivers are up to date.
