FAQ
Knowledge Base Articles
[Gaming NB/DT] Armoury Crate Application Introduction
[Gaming NB/DT] Armoury Crate Application Introduction Armoury Crate Introduction (Ver5.0)Armoury Crate Introduction (Ver4.0)Armoury Crate Mobile Version Introduction (Android/ iOS)Armoury Crate - Installation SOPAniMe Matrix™ Display - IntroductionKe...
FAQBot by Community Manager
  • 776 Views
  • 0 comments
  • 0 kudos
MyASUS Frequently Asked Question (FAQ)
MyASUS Frequently Asked Question (FAQ)Table of Contents [Phone] MyASUS App - Introduction  [Motherboard] MyASUS introduction  [Notebook] MyASUS-Unable to reset GPU mode to default value  [Notebook] MyASUS - Introduction  [Notebook] MyASUS- Settings  ...
  • 1938 Views
  • 0 comments
  • 0 kudos
ASUS Router Plug-n-Share Disks Compatibility List
ASUS Router Plug-n-Share Disks Compatibility List* OS encrypted hard drives are not supported.   Wireless RouterModelFirmware versionMaximumPartitionNumberDisk Format & Maximum Partition Size:File Size:FAT32EXT2EXT3EXT4NTFS       (Read Only)NTFS     ...
  • 2015 Views
  • 0 comments
  • 0 kudos
[Notebook]GoPro Subscription Bundle_Q&A
[Notebook]GoPro Subscription Bundle_Q&AQ:When does the redemption start and end? The redemption begins on October 7, 2025 and ends on December 31, 2027. Q: Which ASUS products qualify for the promotion?ProArt laptops will qualify for a 6-month compli...
  • 132 Views
  • 0 comments
  • 0 kudos
[Notebook]GoPro subscription_eligible model list
[Notebook]GoPro subscription_eligible model list6-month subscription ProArt LaptopH7606WIH7606WRH7606WWHN7306WUH7606WMH7606WUH7606WXHN7306WVH7606WPH7606WVHN7306WIHT5306QA3-month subscription ZenbookASUS LaptopUM3402YAUX3404VAUX5406SAV3607VMUM3406HAUX...
  • 1711 Views
  • 0 comments
  • 0 kudos
[Notebook]GoPro Subscription Bundle_Terms
[Notebook]GoPro Subscription Bundle_TermsTerms and Conditions for GoPro Premium+ PromotionTo support video creators, ASUS has partnered with GoPro to provide a limited-term subscription to GoPro Premium+ (referred to as the “Offer”). These terms and ...
  • 160 Views
  • 0 comments
  • 0 kudos
[Graphics Card] PCIE Interface Operation Mode (Speed) Confirmation
[Graphics Card] PCIE Interface Operation Mode (Speed) ConfirmationThe operation mode (speed) of the PCIE interface of a graphics card depends mainly on the number of lanes and the version of PCIE PCIE comes in different numbers of lanes, such as x1, ...
  • 169 Views
  • 0 comments
  • 0 kudos
<For JP only>[V440FAK]If Cannot make Windows Recovery drive
[V440FAK]If Cannot make Windows Recovery driveIf you met the issue that you could not make Windows Recovery drive, please follow the following troubleshooting.The reference for Windows Recovery drive ; [Windows 11/10] How to create and use Windows re...
  • 135 Views
  • 0 comments
  • 0 kudos
[Computer Chassis] Prime AP303 Disassembly Instructions
[Computer Chassis] Prime AP303 Disassembly InstructionsNotice1. Kindly wear gloves to protect your hands before proceeding with disassembly or assembly. Pay special attention to the corners of the parts to avoid any scratches.  2. When the side panel...
  • 206 Views
  • 0 comments
  • 0 kudos
[LCD-M]How to adjust screen brightness and contrast?
[LCD-M]How to adjust screen brightness and contrast?Adjust the screen brightness and contrast according to what is displayed on the screen. Set the brightness based on your personal comfort level, avoiding settings that are too bright or too dark. Ad...
  • 229 Views
  • 0 comments
  • 0 kudos
[LCD Monitor] Troubleshooting - If the USB port you connected your monitor to does not charge or respond, please refer to this FAQ for solutions.
[LCD Monitor] Troubleshooting - If the USB port you connected your monitor to does not charge or respond, please refer to this FAQ for solutions.A.If the USB port you connect to your ASUS monitor does not charge or respond, please refer to this FAQ f...
  • 231 Views
  • 0 comments
  • 0 kudos
[Headphone] ROG PELTA Frequently Asked Questions
[Headphone] ROG PELTA Frequently Asked QuestionsTri-mode RGB gaming headset with ROG SpeedNova wireless technology, 50 mm ROG titanium-plated diaphragm drivers, refined wireless sound signature, 10 mm super-wideband boom microphone, lightweight 309-g...
  • 369 Views
  • 0 comments
  • 0 kudos
[VGA]ProArt RTX5000 series Type-c Function FAQ?
[VGA]ProArt RTX5000 series Type-c Function FAQ?Question 1: Can I connect devices like USB drives or USB Mouse to the graphics card's Type-C port?Answer : No. The ProArt RTX 5000 Series Type-C port only supports video output and does not currently sup...
  • 276 Views
  • 0 comments
  • 0 kudos
[Headphone] ROG Delta II DualFlow Audio: Frequently Asked Questions
[Headphone] ROG Delta II DualFlow Audio: Frequently Asked QuestionsHow does the DualFlow Audio feature work?Advanced DualFlow Audio lets you listen to two separate sources simultaneously, so you can have a video, podcast, or even music playing in the...
  • 116 Views
  • 0 comments
  • 0 kudos
[Wireless Rouer] How to Recover the Firmware of RT-AX50 Go ?
[Wireless Rouer] How to Recover the Firmware of RT-AX50 Go ?If your RT-AX50 Go becomes unresponsive or malfunctions after a firmware upgrade, please follow the steps below to recover the firmware:  1. Download and Install TFTP Server Software(Non-Asu...
  • 137 Views
  • 0 comments
  • 0 kudos
[Chromebook]How to check battery information?
[Chromebook]How to check battery information?Table of ContentsHow to check the activate date of battery for the first time?How to check more information about battery? How to check the activate date of battery for the first time?1. Open the Chrome br...
  • 334 Views
  • 0 comments
  • 0 kudos
Top Contributors
