Heating issue while charging and gaming after pie
gyanudon13
After pie update phone is getting too much heated while charging and gaming . This problem came after Android p update and I am sure it's not only in my phone. Pls DONt say to boot in safe mode or reset or latest update as I did everything.  PLS SOLVE THIS ISSUE IN NEXT FIRMWARE UPDATE
20 REPLIES 20
Koudmaker
Rising Star I
That is normal that the phone will heat up playing a game will charging. So i don't no why you are reporting this.....
gyanudon13
Well I may be wrong but phone is going up to 45° even in charging not gaming in front of a cooler. Is it normal?
CH_ASUS
Community Legend II
@gyanudon13 , When charging - are you on charging between 0 and 60%? This is the span where the fastest charging will occur - and as such the highest heat.
If you have 45C, and phone is in idle, and charging between say 80% to 100% - 45C could be abnormal - assuming your room ambient temperature is lower (say 24C). It could indicate either some rogue app is running in the background, using a lot of cpu resources - or further examination needed.
Br
CH
gyanudon13
Same problem please solve this fast
My phone is asus Zen phone max pro m1 ,when I charging my phone heating very much also I playing game it get heat very much
