Control Fan Speed
gregeeh
Hi all,
I have a PN64 with Windows 11.
Is there a way to control the fan speed of the PN64 via command line?
TIA
Aureliannn_ASUS
Hi @gregeeh ,
based on your issue, with MyAsus, you can flexibility to use maximum fan speed during heavy loads or switch to a lower speed for silent operation. Thank you.
gregeeh
Thanks for your reply.
Where can I get this MyAsus?
Confirming I can use MyAsus to control the fan speed via the command line while in Windows.
