10-04-2022 04:41 PM
10-04-2022 11:58 PM
tkhfung@tkhfung
- System: Windows 11, Firmware 311
- Battery or AC: Battery
- Model: 9400CEA; 2TB SSD; 32gb DDR4 RAM
- Frequency of occurrence: Regularly
- Reset OS:
- Screenshot or video:
Detailed description:The advertised battery life is over 24 hrs, but even if I run minimal web applications & programs (like Internet Edge, Avast antivirus), I cannot work for more than 7.5 hrs before the battery is < 10%. I even turned off cloud programs like OneDrive & Dropbox, but without much improvement. I would be happy with even 12 hrs of battery, but actual battery life is a lot shorter than listed. Any advice?
Expertbook B9400CEA Battery Life Shorter than Expected
10-07-2022 09:09 AM
Falcon_ASUS@Falcon_ASUS Thank you. I've already tried all of those those battery saving settings.https://zentalk.asus.com/en/discussion/64535/expertbook-b9400cea-battery-life-shorter-than-expected
Please refer to the following FAQ for troubleshooting.
https://www.asus.com/support/FAQ/1043914/
10-10-2022 08:02 PM
tkhfung@tkhfunghttps://zentalk.asus.com/en/discussion/comment/231312#Comment_231312
But why would the battery life be so extraordinarily short < 8 hrs for a new laptop? (It has been this way from the beginning), when the advertisement is 16-24hr+?
What is the next step?
11-12-2022 10:00 AM
