Expertbook B9400CEA Battery Life Shorter than Expected
tkhfungtkhfung Level 1
edited November 12 in Commercial
  1. System: Windows 11, Firmware 311
  2. Battery or AC: Battery
  3. Model: 9400CEA; 2TB SSD; 32gb DDR4 RAM
  4. Frequency of occurrence: Regularly
  5. Reset OS:
  6. Screenshot or video:
Detailed description:The advertised battery life is over 24 hrs, but even if I run minimal web applications & programs (like Internet Edge, Avast antivirus), I cannot work for more than 7.5 hrs before the battery is < 10%. I even turned off cloud programs like OneDrive & Dropbox, but without much improvement. I would be happy with even 12 hrs of battery, but actual battery life is a lot shorter than listed. Any advice?
Comments
