ROG Phone 6 Pro Hotspot problem
I have multiple devices. The Sim card is installed in ROG Phone 6 Pro, so all the other devices connect to its hotspot. When the other devices sleep, they disconnect from its hotspot, but reconnecting when woken up.
I've tried the configurations below:
Security: WPA3, WPA2, WPA2 or WPA3 adaptive
Type: WiFi 6, WiFi 5
AP band: 2.4 GHz, 5 GHz, Dual Band
Turn off hotspot automatically: Never
I've tried all the combinations above, reset all settings and turned off developer options, but this problem is not solved yet.
Comments
Sign In or Register to comment.
